Old 05-18-2009, 12:46 PM   #1
ProfessorPaddle's Avatar
Un-even Tire Wear
Could anyone give me tips or ideas for diagnosing what would cause my rear passenger side tire to wear significantly faster than the others.
Vehicle is a 2006 E350 6.0L PSD with a Quigley Conversion, No Interior upgrades other than my own, no secondary gas tanks, and no weight distribution changes or mods (IE Racks on one side, cabinets on one side etc...).
The other three tires seem to have a solid 1/8th to 1/6th inch more of tread left on them. With the other rear tire having just a hair less than the fronts.
Any ideas?
2006 E350 6.0L (VanDelizer)
1986 Vanagon Syncro 3.3L SVX (battleCat)
1984 Vanagon GL (Chuckie)
1980 Vanagon Westy (Taylor)
ProfessorPaddle is offline   Reply With Quote
Old 05-18-2009, 01:27 PM   #2
Re: Un-even Tire Wear
I'm going to guess you haven't been rotating your tires every 5-10K. If it is wearing evenly, no cupping or signs of misalignment, then that tire may just have a slightly different rubber compound (different batch?) and they are all wearing normally.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 05-18-2009, 08:22 PM   #3
Greg In Austin's Avatar
That tire is your power tire, and for us it produces more heat than any of the other three.
Rotation will be important, as will tire pressure. Keeping the tire pressure in the higher range towards the max cold pressure should help keep tire wear even and slower.
There are ways to perform a 4 wheel alignment on many vehicles, but I have never heard anything about it for vans.
Greg in Austin
http://badge.facebook.com/badge/1232...3.32047100.png
Old 05-19-2009, 09:12 AM   #4
Power tire???
Are you guys pullin my leg, I have never heard of such a thing? Doesn't the rear diff distribute power evenly ?
Egads I have done about 12k without rotating on fresh tires... that seems like a pretty frequent rotation requirement. Considering in the summer I put on an easy 15-25k.
~J
Old 05-19-2009, 09:53 AM   #5
4wheelparts will void my warranty if I don't rotate every 5K miles or less. Just a thought.
As for the rest...
and then
everything changed
Old 05-19-2009, 12:08 PM   #6
geoffff's Avatar
Rotating your tires will only fix the symptom, not the cause. Even with rotating, the increased tire wear will cost you in the long run. It'd be nice to know why this is happening.
2004 Ford, SMB 4x4, RB-50
http://octopup.org/sportsmobile
Old 05-19-2009, 01:48 PM   #7
Jage : If you could edit that post I made to read "Rotated within warranty requirements"
Now I guess its time to do the rotation...
Geoffff : Contrary to popular belief in my town, I am not a complete dumb ass! I was already aware that my tires needed to be rotated, just not at those intervals. Which like you mention brings me back to the original post.
Not to but ... Power tire is the only suggestion so far on why that tire is treading faster. Pressures are dead on and even all around so that should not be a factor. Anyone else have an idea, ... softer leafs on one side???
Old 05-19-2009, 02:01 PM   #8
Driving the wrong way around NASCAR racetracks, making only right-hand turns?
BroncoHauler is online now   Reply With Quote
Old 05-19-2009, 04:54 PM   #9
winvest's Avatar
Do you have the wheel spacers on the back axle? If so, maybe the one on that side is causing your wheel to be out of alignment
'07 E350 4x4, voyager top, custom interior, prorock 60, arb front & back, aluminess front & back, hella lights, extreme air, braun wheelchair lift.
"Two roads diverged in a wood, and I took the one less traveled by. And that has made all the difference." - Robert Frost
winvest is offline   Reply With Quote
Old 05-19-2009, 06:59 PM   #10
I knew I liked the way Herb thinks !!
I can see it now...... the new NASCAR SMB Series !!
Greg in Austin
