Originally Posted by James4
Mike T,
What are your axle weights and tire specs?
James
Ok, here ya go:
CAT SCALE RESULTS
Front axle: 3500 pounds
Rear axle: 3500 pounds
(Seriously, they read within 50 pounds of each other.)
Notable as-weighed-with-the-van contents:
Me, 1/2 tank of gas, half of usual provisions.
Tire size, Make, Model:
285/70R17 BFG KO2
Rim Size / Rim make&model:
17x9 American Racing Baja
Calculated (as weighed) load to be carried per tire:
3500/2 =
1750 pounds per tire
Recommended tire pressures from that same Toyo / Tire & Rim Manufacturer-originated chart I posted the link to earlier:
35 PSI -- 2105 Pounds
40 PSI -- 2315 Pounds
45 PSI -- 2510 Pounds
50 PSI -- 2755 Pounds
55 PSI -- 2900 Pounds
60 PSI -- 3050 Pounds
And....after all of that....
....the actual **on-road** tire pressures that I am
currently choosing to run (though I'm still (perpetually) experimenting...)
Fronts: 40 pounds
Rears: between 40 and 45 pounds (varies depending upon how much additional gear is loaded in the inside rear storage areas and exterior rear racks for a trip.)
You might argue....
....that at 40-45 pounds, I'm guilty of ignoring my own advice to "read the charts"...that it appears I am running too high a tire pressure for what those charts advise..
..and you'd be halfway right! But in my case I'm so "over-tired" with the big 285's that I can't effectively "dip out" of the safe load window. For this van's weight, I'm safely covered no matter how low on the chart I dip.
Even if I ran 35 pounds (the lowest safety-rated PSI range even shown within the charts indications), I'd still have an overabundance of safe load-carrying capacity.
So in my case, since that official load/PSI table had essentially given me the confident all-clear "foundation" of what PSI range is truly approved and safe (in my case it was essentially without any restrictions....)....then it came down, ultimately, to choosing a PSI setting based on personal tire ride/handling preferences.
Again, the chart says I could run 35. And I might end up doing that. But 40 is the lowest I've ever run as it is, and it rides great. Any lower than 40 and I'll probably want to pick up one of those IR tire thermometers that 86Scotty recommended, just to confirm *one more way* that things are running cool.
Oh wait! I forgot. Back when I first got these tires, when I was on a very-similar-to-yours intense drive to determine what was the correct tire pressure.....
I also found yet another chart! And it agreed 100% with the numbers on that first .pdf link chart from earlier. This is an un-branded, direct-from-the-wheel-and-tire-manufacturer chart. For my 285/70R17 size tires, its all the exact-same indicated safe load/PSI ratings.
And yet....for my van, 40 is great! Seems like it's that "Goldilocks" tire pressure. Corners nice and stable, yet has comfortable bump compliance on the highway.
So sometimes you've got to damn the charts, lol.... (In the right instances.....)
But never should you air your tires up to a pressure BELOW what the charts recommend, except when doing slow travel off-road. When traveling rough/torn up fire roads, we've aired down happily to 30 pounds and that truly created a magic carpet ride.
Hey, before I forget --- I must ask --- apart from your tire pressure sensors going off, what was it in particular about the lower (50 pound) PSI setting on your van that made you feel it was "too low"? Did your tires actually look flat? Or was there a noticeably mushy/floaty quality to how your van handled? Unless a tire is truly underinflated to a level below it's safe PSI/load range....then typically a less-aired-up tire yields a better (smoother) ride. (Less abrupt feel of impact over bumps/freeway expansion joints). Curious for more understanding of how your ultimate PSI setting is felt to be "the best ride."
