Well I dug into this as well... and have a few things to add based on my read of some Eaton resources:
1 - The diode supression for the Eaton unit is actually there to protect your chassis wiring since the voltage spike is going to come FROM the E-locker disengaging. It is basically a giant coil.. so it will create what is called "flyback voltage" when it disconnects -- this is the circuit you want a "flyback" or "freewheeling" diode on so it doesn't feed this high voltage into other--perhaps sensitive--things on your chassis wiring:
From Eaton:
Wiring Diagram:
Probably all the more important on the F-Series -- since the E-locker is controled by a computer with sensitive electronics.
This begs another fact -- the diode supressed relay suggested here isn't going to give this feature since the flyback diode on that unit is on the coil side of that relay -- not on the contacts.
The relay coil will create its own "flyback" voltage when you turn it off -- but this is a different "flyback" voltage than the one coming off the e-locker.
Thus -- by all means -- use a diode supressed relay -- but to do this right -- one should also install a diode as in the Eaton diagram attached.
Sources:
https://www.eaton.com/us/en-us/produ...cker-faqs.html
https://www.eaton.com/content/dam/ea...-schematic.pdf
Also -- it seems this unit isn't an Eaton (nor GKN) -- but is made by Sterling for Ford directly:
but now I'm just being nit-picky -- I'm sure all of these units use the exact same mechanics and are probably built to almost identical spec!
