Old 04-02-2012, 10:24 PM   #1
ecopco's Avatar
2012 170 2500 Sprinter with factory rear a/c
Ok folks this is my first post after reading all the great info on this site.
I'm thinking of ordering my van with factory rear a/c. I also want to add a 110v danhard system to use when hookups are available. Does anyone know if this will present any issues? I like the fact that the factory rear air will be covered by the MB warranty and allow for quick cooling in the van. I also want at least 1 fantastic fan or similar. Is there enough real estate on the roof to make this work. Anyone have any similar set-up. Thanks.
ecopco is offline   Reply With Quote
Old 04-03-2012, 05:54 AM   #2
Re: 2012 170 2500 Sprinter with factory rear a/c
If I recall right , MB has 2 different rear ACs. 1 is tied into the front AC compressor, the other has its own engine driven compresser. I got a much better, aftermarket rear AC, (They are an MB approved upfitter) Proair http://proairllc.com/condensers.html (I have the 941) (they have approved shops to do installations around the country)Mine was installed by a shop thru SMB texas. I didnt want the MB, as its roof mounted ,you have no choice in where its mounted and its placement may mess up your plans for conversion,... and I needed the roof for my 110AC , solar panels, maxi vent, satellite . I have a few friends that had the 110v Danhards and where not happy as they dont have as many BTUs as the 13,500 BTU or 15000 BTU roof mounted 110 ACs and could not keep the 170wb sprinter cool when parked in summer. Mine is a coleman 15000 btu
k9sprinter is offline   Reply With Quote
Old 04-03-2012, 09:13 AM   #3
ecopco's Avatar
Thanks K9Sprinter. Great photo of the top of your rig. Did SMB TX do your conversion or did you have it done elsewhere? I hadn't considered using other authorized upfitters for specific conversions but it makes sense from a warranty standpoint. What type of generator did you go with? Any problems or issues? Thanks.
Old 04-03-2012, 10:04 AM   #4
Yep , Texas did it , Paul is the best!!!!, The gen is a powertec (made for sprinters) http://powertech-gen.com/products/all-g ... ptrv-3sv2/ alsoi installed by texas ... the power tec gen is great... we had a storm , lost power for 6 days , I used the gen to power my house fridge and lights , tv, only used 1/2 tank in 6 days
Old 04-03-2012, 11:01 AM   #5
I would avoid the factory rear AC as K9 points out. Many people experience leaking roofs around the location of the AC. Please see Sprinter Source for more info on troubles with factory roof AC. I opted for no rear AC on my Sprinter and instead use a MaxxAir fan(can be run in the rain up here in the PNW).
frostyone is offline   Reply With Quote
Old 04-03-2012, 12:38 PM   #6
ecopco's Avatar
Did you order factory bracket for the additional a/c compressor? What other factory must haves in order to properly upfit your A/C and power needs?
Old 04-03-2012, 12:53 PM   #7
Heres my order from MB , I got the factory installed AC bracket (it can be installed later for a much highr price) roof rails-- for the awning, upgrade your starter battery to the 95 amp AGM and the dont get the aux battery, as your SMB build includes an AUX system , get the 2 extra keys (its ALOT more later for keys)
Packages
V24 -RPM Variable Governor Package
V61 -Lighting Package
V21 -Security Package
V25 -Multi-function Wheel/Display Package
V04 -Cold Climate Package
V16 -Rear Heating Package III
V52 - Heavy Duty Suspension IV PACKAGE
V37 -Heavy Duty Front Axle PACKAGE
F12 -Window Fleet Package
V06 - Comfort seating Pkg
V01 - Premium Pkg
V46 Parktronic PACKAGE
options
L16 Fog lamps
W73 rear door step gray
VC5 Door sill protective edge
V93 wooden floor deleation
T85 assist handles left rear door
T74 assist handles sliding door
T12 sliding door 2 stage
SZ8 storage net pass seat backrest
SZ7 storage net drivers seat backrest
R98 wheels painted black
N63 bracket for aux ac compresser
LO5 daytime running lights
FZ9 2 addional keys
FK3 chrome raditor grill
FF8 storage slot at front under roof liner
D13 mounting rails for roof rack
CM9 detachable parts, painted pure white
C72 Bumper and corner bumper primed in white
W70 tinted glass in all windows
ES2 12v outlet rear
ED4 95 amp agm battery
XB5 11000 lbs
D93 Deletion of bulkhead
RM1 M+S tires
Brilliant Silver Metallic
Lima Black Fabric seats
