Momentum Van Modifications May-Aug 2019
Van has been dropped off at Momentum Vans in Arlington WA for modifications while I’m at sea again.
Brian and Brianna, the owners of Momentum Vans, are fairly new on the NW van scene but are putting out some really fantastic work. The fit and finish of their work is just beautiful. I love seeing this kind of pride in workmanship. They are of huge benefit to our NW van scene. You can follow them on Instagram as well.
For us, it’s an ever continued quest for perfection and improvement.
The van had a couple issues which needed repair, and in addition I wanted a couple items improved:
1. Location of controls and access - Both on main control panels and wiring runs in overheads. Placement of D5 controls where we wanted. Redo main control panel.
2. Leaks - minor leaks, modifications will allow easier access.
3. Vehicle start battery drain- addition of battery tender to rectify this issue when van is stored.
4. Addition of Blue Seas Panels - improve versatility and ease of use.
5. Possible overhead liner work - this will depend on access and if the work is feasible, which is still being researched. I would prefer access to wiring runs and roof penetrations.
The main work list is attached.
I will post photos as the work progresses.
2017 4X4 2500 144" Stone Grey High Top
