FWIW, I just saw a fairly new 4x4 Sprinter in Jupiter FL with Nitto Grappler 285-75R16 tires. Those would be about 32.8" diameter and a little bigger than I thought would fit. Guess he could be rubbing in turns, but you couldn't see anything looking in the wheel wells.
