Old 01-10-2013, 11:52 AM   #1
High Roof VS Penthouse Top
What is the reason that SMB won't put up a PH on a high roof sprinter?
I plan to use the PH for the main bed to save some space below and I love the extra storage space of the high roof.
Thanks for the help.
Vyed is offline   Reply With Quote
Old 01-10-2013, 12:07 PM   #2
canoe4me's Avatar
I looked into this one too.
The main reason seems to be that the taller roof is not structurally sound enough for the penthouse
The next reason is that the taller any extra weight gets, the stability of the van gets worse.
A final reason given is that the taller vans get narrower as they go up and that the bed would be a very narrow fit for the high roof sprinter.
I have a sprinter with penthouse and the bed is fairly narrow as it is.
The system seems to work for me because when I'm out of bed (and parked) I can raise the bed up to the ceiling and have plenty of head room. I only put the bed into position when i sleep so headroom is not an issue unless the top is down.
canoe4me is offline   Reply With Quote
Old 01-10-2013, 12:48 PM   #3
Re: High Roof VS Penthouse Top
Thanks for your reply. How wide is your PH bed?
Old 01-10-2013, 12:58 PM   #4
I think they fit a full/double width bed up there, but it's shorter than a typical mattress (made up for by extra headroom where the bed meets the roof). Good for two if you know each other well, otherwise one.
I have a PH top, but am envious of the upper cabinets everyone else has in their high roof. Depends on what you need...
gs1s is offline   Reply With Quote
