Old 03-08-2011, 07:36 PM   #1
Looking for Photo of Inside Rear Doors of Mercedes Sprinter
Greetings. I am in the process of finishing up design for a SMB conversion of a 2011 Sprinter that is on its way. I'm trying to figure out if there is any space in the rear doors to put storage. I need to see what's behind the "paneling" ... I find plenty of photos of the inside of the rear doors fully assembled, but I need to see how big the "holes" are behind the paneling and how deep they are. The only photo I found after an hour of searching on line turned out to be a Dodge Sprinter's rear doors, which I'm told are different. So, does anyone have a photo of the inside of the rear doors taken when their Mercedes Sprinter was being converted? Many thanks in advance.
bluesprinter is offline   Reply With Quote
Old 03-09-2011, 08:57 PM   #2
Re: Looking for Photo of Inside Rear Doors of Mercedes Sprin
Don't know why the doors would be different.
Lists 2006+ in rear doors:
http://www.cabmasters.com/new-van-parts ... te-g3.html
Listed as 2010 Sprinter:
Don't know about the bottom, but it looks like you could get an extra kleenex box above each window!
Old 03-09-2011, 09:57 PM   #3
Thank you! My goal is to find a way to store the fresh water hose and the one-inch dump hose in the doors rather then elsewhere in the coach. Too much other stuff under the couch/bed in the rear (17 gal fresh water tank, water pump, inverter, circuit breaker panel). Prefer not to store them up front. If the "pocket" behind those lower panels is 2 inches deep, it should be possible.
Old 03-10-2011, 07:07 AM   #4
Before and after the door panel.(notice 1 side is a little bigger) Hope this helps.
meeeach is offline   Reply With Quote
Old 03-10-2011, 08:24 AM   #5
Thank you!
Definitely different from the Dodge Sprinter rear door. Now I know I cannot fit the hoses there. Perhaps I'll reduce the size of the fresh water tank to 10 gal (With 4 gal in the water heater, and only an 8-gallon grey water tank and 5-gallon black water tank, 14 gal should be enough, considering I generally plan to use shore water and dump hookups)
Old 03-10-2011, 09:17 AM   #6
Theres is a dif in a TIN (2002-2006) vs a NCV3 (2007up),but theres NO diff between a dodge vs MB or FL (except the badging)
Old 03-10-2011, 09:28 AM   #7
.the website is wrong..it should be 2007+ ..... 2006 was the last year for the old style sprinter (tin)
Old 03-10-2011, 01:25 PM   #8
Looks like from meeeach's photos you could go further down with the pocket too.
Old 03-10-2011, 01:48 PM   #9
Yes, it does look that way. I wonder what's behind the structural member above that lowest opening. If it's clear, then it *might* be deep enough to get a rolled up hose in there. Perhaps someone has done something like that with the MB Sprinter?
Old 03-10-2011, 03:06 PM   #10
Looks are deceiving........your forgetting about the curvature of the doors @ the bottom (thiner) and the indentation for the license plate (We wanted bigger cavitives also !!!!)
