Immense thanks to Tim and his lovely wife Laura for allowing us to pick their minds for several hours today. We learned an incredible amount of technical stuff and made some outstanding new friends as well.
Question for Tim-Is the Apple CarPlay just software that goes on the OEM sound system in place of Becker Pilot Map or is there a different piece of hardware that has to be substituted?
WrinkledPants, I am leaning toward keeping OEM front bumper and embedding front winch like you did (Sorry Tim!
). Also, I found some other options and standard features lists and I think I have removed most of the stuff in my list that is already standard or not available. You and Tim both convinced us the alarm is worth having.
Thanks to Laura-you seem to have given my wife more confidence about going off road and away from civilization. She had no qualms about backpacking into the backcountry when young, but worries about us being stranded somewhere now in our 60s.
I will start on the SMB part of the build and post-SMB changes in a couple of days. We may make Van Compass wealthy! BTW-they say they are moving to Spokane this spring.
Here is my updated list that I'll probably send to Brian on Sunday night. Anyone is welcome to give feedback/suggestions for change before I do.
144’ WB (M2CA144) Tall Roof (DO3) Sprinter Cargo Van (Only OEM Windows: Driver & Front Passenger)
X30 Low and High Range 4x4 With 6 cylinder Diesel Engine
Exterior Color: Blue/Grey; Interior Color: Tunja Black Upholstery
CO1 Driver Comfort Package
F29 2 additional keys
SB2 Luxury Passenger Seat
SB1 Luxury Driver Seat
FJ1 Instrument Panel Storage Bin With Hinged Lid (What was the reason for deleting this?)
E46 12V Power Outlet @ Driver’s Seat Base
CO2 Driver Efficiency Package
MS1 Cruise Control
FR8 Rear View Camera
E1N Becker Map Pilot Navigation System (We Want To Use Apple CarPlay System In The Unit)
L16 Fog Lamps
CO4 Active Safety Plus Package With Active Parking Assist
LA1 High Beam Assist
Y45 Road Hazard Light/Emergency Flash Light (Omit if this is hand held.)
H21 Windshield Glass With Shade Band Any conflict w/ F49 or W70?)
EZ8 Park Aid System FRT & RR
JA7 Blind Spot Monitoring
JK3 I/P Cluster Pixel Matrix
Y10 First Aid Kit (Omit if Possible)
JA6 Collision Prevention Assist
CL4 Multi-Function Steering Wheel
JA5 Light & Rain Sensor
F68 Exterior Mirrors Power Heated
JW5 Lane Keeping Assist
LDO Overhead Control Panel With Reading Lights
ZH4 Downhill Speed Regulation
FY1 Security Alarm
D13 Roof Rails
HO4 Insulation Front
H20 or F49 Electronically Heated Windshield
W70 Privacy Glass
E40 Trailer Hitch Wiring Prep
T12 Two-Stage Slide Door Passenger Side
X90 & X93 Delete Badges
LGO or X13 Bi-Xenon Headlamps (Daytime Driving Lights Set to Off)
F46 Headlamp Cleaning System
VA7 Storage Compartment With Net Rear Doors
KL1 Auxiliary Fuel Sending Unit With Fuel Tap
I51 Fuel Gauge Optimized for Auxiliary Fuel Tap
LB9 Illuminated Exits
N62 PTO @ Front With Additional Alternator Bracket
SR8 Driver’s Seat Swivel
SR9 Passenger Seat Swivel
H16 Heated Driver’s Seat
H15 Heated Passenger Seat
S27 Storage Net Driver’s Seat Back
S28 Storage Net Passenger Seat Back
T74 Assist Handle Slide Door
X26 or R91 and R92 Delete Spare Tire And Bracket
MT4 High Idle Control Driver Adjustable
RM9+RF1, Mfg. Code 10, Tire Brand Continental (KO2 largest available on Method Std. Black Beadlocks)
CT1 Vibration Absorbers with DRS
V93 Wood Floor, Delete
Would like to discuss optimum start battery.
Can a single Espar D5 provide cabin hot air, cabin hot water, and engine pre-heat? I have heard that there is a kit which will allow this? Would it be better (even possible) to use D5 for water/air and separate factory Espar (Option H12) for engine pre-heat? I prefer one single unit to do all if possible.
Are either of the following already included in build? If not, can I get them?
X21 Heavy Duty Front Axle Package
X17 Suspension Package I or X19 Suspension Package III
