Originally Posted by BrianW
I can't seem to find the definitive answer on this. Will 16" steel wheels from a 1998 E250 clear the front brakes on a 2012 E250? I know the bolt pattern and all that will line up, just not sure if the steel wheels have enough clearance for the bigger brakes on the 2008+ vans. Thanks!
When I swapped my '03 brakes for the '08 & later versions the same steel wheels were used, fit perfectly.
Clearances are a bit slim at least as compared to the earlier calipers, rotors etc. In over 50K miles so far there have been no problems or issues with stock steel wheels fitting the larger brakes.
HTH
