Old 09-10-2010, 10:00 AM   #1
Ac dripping on passenger floor
Has anyone else had their ac evaporator dripping on the passenger floor area? I can't find the source. Found the drain hole under the evaporate under the hood and it's clear, but still have a damp carpet on the passenger side. Any helpmappreciated before I try to pull plastic under the dash to try to find it
thanks, Brian
Bigduke6 is offline   Reply With Quote
Old 09-10-2010, 10:18 AM   #2
Viejo's Avatar
Re: Ac dripping on passenger floor
Are you sure it's just water? Could it be engine coolant from a bad heater core?
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 09-10-2010, 12:32 PM   #3
Cold water with no coolant smell. Seems to be coming out all around the plastic box under dash. I think the evaporator is outside the firewall. Will run the ac on the way home from work then try to find source when I get home. Very hot and humid here.
Brian
Old 09-10-2010, 02:54 PM   #4
AndrewST's Avatar
If the AC isn't related and it has been raining, could also come from the windshield that isn't watertight... happened on mine. Top center part was not tight and as the slope was going down on the driver side, noticed it there. But had also water marks on the passager side.
Old 09-29-2010, 02:52 PM   #5
blkjak's Avatar
thanks, Brian
if the drain hole pipe is horizontal add a turn down "90 degree".
road wind could be the problem.
blkjak.
http://pic50.picturetrail.com/VOL165.../392572714.jpg
2005 ford e-250 extended crew cargo van "stealth sleeper".
blkjak is offline   Reply With Quote
