Old 08-23-2015, 04:08 AM   #1
Aftermarket HMSL?
Anyone here had occasion to install an aftermarket High Mounted Stop Light? Need something fully encased and weather tight to replace a sealed unit I have on a raised roof van, MobilityWorks was the original converter.
TIA
Old 08-23-2015, 11:56 AM   #2
MadScience's Avatar
Re: Aftermarket HMSL?
Truck/trailer lights come to mind. I have two similar to these on my rack, you could obviously just wire on to the brake connection only in the center:
http://www.amazon.com/Autosmart-Kl-3510 ... iler+light
Old 08-23-2015, 01:13 PM   #3
BrianW's Avatar
I think SMB sells them on the sportsmobilestore.com site
Old 08-23-2015, 01:22 PM   #4
Just came across these today looking for something else:
http://www.rvandvansurplus.com/brakelig ... cletype=RV
TeleSteve is offline   Reply With Quote
Old 08-24-2015, 03:32 AM   #5
Thanks for the help and input guys----more than a few good choices. I did find Truck-Lite has this one: http://www.amazon.com/gp/product/B00...?ref_=pd_ybh_3 which is one option. Prices are all over the map on it though......pays to shop around some times.
Our friend 1der is looking into one other option----I'll make a choice at some point.
Thanks once again----knew y'all would have great input!
Old 08-24-2015, 06:44 AM   #6
audisnapr's Avatar
Another option is to retrofit the existing SMB mounted tail light.
I bought this: http://www.amazon.com/gp/product/B004O1 ... ge_o00_s00
took it apart and placed it inside the existing Sportsmobile housing.
4amRacing
audisnapr is offline   Reply With Quote
Old 08-25-2015, 04:07 AM   #7
After looking at my current CHMSL it doesn't need replaced as originally thought, rather it needs re-attached.
A bit of hi-tek adhesive and all is well once again. Even so I greatly appreciate y'all for helping---gives good insight should a full-on replacement be needed in the future.
Agnes
alta825
2006 Ford E350
Belize
