I ran the wire from my 3rd eye brake light camera down into the back drivers side door jamb. There was a pass through to the interior. From there I ran it through the cabinetry, then behind the header above the side window, then above the headliner over the drivers seat and down behind the A pillar trim to under the dash. The mirror monitor wire runs above the headliner to the drivers side A pillar and down to under the dash. There is a power supply/video splitter mounted under the dash. I sourced power and reverse from the engine compartment fuse box using tapping the tow harness fuses. There was a pass through the firewall just above the gas pedal.
I bought the rig from Rear View Safety. It does have that single lens fault.
'07 GMC 2500 6.0
