Old 04-14-2014, 09:46 PM   #21
Re: Bed lining the side or rocker panels.
You have to sand and ruff up the paint for the liner to stick well. Not much beyond that, but it is critical.
I know there was some talk about painting fiberglass fender flares on the jeep forum, in the monstaliner thread, probably find it if you do a search.
My opinion, (guess) is that a liner like herculiner that has some flexibility would do fine, but a harder ones like monstaliner might not do as well. But that is a complete guess.
tsbrewers is offline   Reply With Quote
Old 04-25-2014, 02:15 PM   #22
Hey Spoolin - Looks awesome! Does that rough LineX finish collect dirt in the crevices? Do you need to use a scrubbing brush sometimes when it gets really dirty?
Originally Posted by Spoolin
I Line-x'ed my whole Van and two toned it where the rockers are. Main color is Olive Green and the rockers are black.
magentawave is offline   Reply With Quote
Old 07-21-2014, 01:40 AM   #23
Sorry for the long reply, was out of the country.
To clean it I power wash it. A brush would work fine but better a stiff one than a soft one. And it does collect dirt more than a paint job normally does but it's not that bad.
2006 Express Duramax 2500
Spoolin is offline   Reply With Quote
Old 07-21-2014, 07:16 AM   #24
When you all are rhino lining the penthouse top are you masking over the bolts and rubber grommets or simply spraying over them?
Walker is offline   Reply With Quote
Old 10-28-2014, 09:33 PM   #25
MrHenrietta's Avatar
Thinking about doing this myself.
1999 7.3 4x4 RB50 SMB
MrHenrietta is offline   Reply With Quote
Old 10-28-2014, 09:38 PM   #26
BajaSportsmobile's Avatar
I just did mine last week. Replaced all the bolts, nuts and washers and sprayed over them.
AgileOffRoad.com
Old 10-29-2014, 02:43 AM   #27
Removed all the washers, grommets and bolts, sprayed top then put in all new stuff.
Old 10-29-2014, 06:33 AM   #28
JohnandMandi's Avatar
We replaced all of ours then had them sprayed over.
-John
2001 7.3 E350 Ujoint 4" w/ SMB Penthouse
johnandmandi.com
JohnandMandi is offline   Reply With Quote
Old 03-15-2015, 02:41 PM   #29
Can I see some of your tape lines in, and around the door jambs?
Thanks
Morgan
01 Eurovan Weekender
04 E350 rb V10 Wigley
macdadmorgan is offline   Reply With Quote
Old 03-15-2015, 02:48 PM   #30
I used Henry's roofing compound. It's elastomeric paint and needs to be thinned with dihydrogen monoxide.I tinted it a chocolate milk color, sanded and wiped down with mineral spirits and painted it on with a brush. A gallon did almost the entire floor of my SWB Chevy and was a bunch cheaper. Any elastomeric paint will work.
"What'$ that funny noi$e?
Serenity
Makalu1
Jnlola
jnlola
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
