Old 03-16-2015, 10:29 PM   #41
Re: Bed lining the side or rocker panels.
$$$$$ and a macho name
"What'$ that funny noi$e?
Old 03-16-2015, 10:38 PM   #42
I was thinking of coating my entire Toyota Sunrader motorhome (has fiberglass shell) with something like Monstaliner but Monstaliner is too expensive.
You really don't think the expensive stuff is any tougher? I'll look into this more but if that's true then you just saved me hundreds of dollars!
magentawave is offline   Reply With Quote
Old 05-11-2015, 07:22 PM   #43
Anyone have, or could get me some pics of your tape lines on the doors and jambs. I just got my raptor liner kit in and have to think how I am going to do my masking.
Thanks.
Morgan
01 Eurovan Weekender
04 E350 rb V10 Wigley
macdadmorgan is offline   Reply With Quote
Old 05-12-2015, 08:00 AM   #44
vwteleman's Avatar
Quarter for scale:
Rear left quarter panel:
Passenger-side quarter panel & door:
ImageUploadedByTapatalk1431438870.421123.jpg   ImageUploadedByTapatalk1431438894.404180.jpg   ImageUploadedByTapatalk1431439110.169940.jpg
Old 05-13-2015, 07:47 PM   #45
Thanks your the man, any chance I can trouble you for a shot of the transition with the door open?
Thanks
Morgan
Old 05-13-2015, 08:09 PM   #46
vwteleman's Avatar
Driver's door, looking forward:
Driver's door, rear:
Passenger side 60 door:
ImageUploadedByTapatalk1431569195.957873.jpg   ImageUploadedByTapatalk1431569223.574127.jpg   ImageUploadedByTapatalk1431569248.822562.jpg
Old 05-14-2015, 03:41 AM   #47
Awesome!!! That's exactly what I wanted, and needed to see.
Thanks a ton!
Old 06-19-2015, 08:37 AM   #48
Any ideas about using the 289 on the outside of the van? I saw considering using Raptor or Monsta liner tinted but this might be a cheaper alternative if it will hold up to UV. Maybe an additive?
89srule is offline   Reply With Quote
Old 06-19-2015, 10:13 AM   #49
Another possibility might be some of the new wood/concrete deck paints. They are flexible, tintable in a range of colors, pretty inexpensive and give good coverage. The stuff I got for another project was about $35/gal, color tint included. Got to be tough as hell too if it is designed to be used on decks and in full sun.
I want to cover the 80's graphics on my van and after seeing how well it worked on wood, I sanded a small section of the van with 220 grit and rolled on a sample of the 2x. Looks pretty good and is surprisingly smooth though it did not cover as well as I was expecting. I'll try some of the 4x next time. I suspect the 10x would look a lot like a full Line-X paint job, it has a pretty coarse surface texture.
Incidentally I did try adding some sand to a small sample as well. Poured sand onto a wet first coat, let it dry, brushed off the excess then did a second coat, all to see if it would also give a good non-skid surface for the PH top. Seems to work really well, so well you don't want to kneel on it in shorts!
Old 06-20-2015, 08:32 PM   #50
What was the material you used?
