Old 04-17-2009, 05:53 PM   #1
Bushwacker Flares on Ford E-350 2 WD
Hi,
Has anybody installed Bushwacker Flares on a 2 wheeldrive E-350? I am curious how the van will look without lifting it or only lifting it slightly (i.e. 2 inches). I would like to get wider tires and flares but because of my parking situation I can't raise the height of the van. Photos would be appreciated.
Thanks,
AHuey is offline   Reply With Quote
Old 04-19-2009, 07:45 PM   #2
Re: Bushwacker Flares on Ford E-350 2 WD
No expert here, but you'll have to match the tire size to the lift. On my pickup I went with a larger and wider tire than I was normally running which was well over stock. Twice I ripped off one of the front bushwackers in a tight turn driving into a rut. I went back to the original tire size that I originally was using to prevent this. Rim offset is also a factor. The style of mud flair I was using was a hard plastic and more prone to break; a soft rubber type flair might not be as much of a problem. Good Luck.
Dave B
Old 04-21-2009, 11:18 AM   #3
I have ATS flares. Van is not lifted except for about an inch due to heavier rated coil springs (4400 I think... whatever is the next step down from 4600).
Running 265/70R17 in the front (235s in the rear since its a dually). Tires fit fine, but there is not enough space for tire chains when turning. I trimmed the fenders near the door before installing the flares. Before next winter, I'll trim the inside of fender flares too (outside of fender flares will not need altering).
Reunel rear bumper
Old 04-21-2009, 11:57 AM   #4
Thanks to the both of you for the replies. The information is definitely helpfull.
Old 07-16-2009, 09:13 PM   #5
Here are my Buswacker Flares installed on my 2008, 2-Wheel Drive Ford E-350 (passenger van camperized).
Bushwacker Flares 003_converted.gif   Bushwacker Flares 004_converted.gif   Bushwacker Flares 005_converted.gif
Old 09-04-2009, 09:32 PM   #6
can these flares work with a slider?
any pics?
dabadie is offline   Reply With Quote
Old 09-04-2009, 09:39 PM   #7
There is a version that works with a slider:
http://www.autoanything.com/fender-flar ... 8A0A0.aspx
2014 Ford E-350
tlg
"Campy"
campy
