Old 06-07-2007, 01:22 AM   #1
JoeyNick's Avatar
Cab and body removal
I found this link on another website and though you'd find it interesting.
It shows the body being removed from a Ford van for engine work.
http://www.forddoctorsdts.com/photographs/index8.php
Let's hope this is never one of us.
--Joey "Nick"
in New "Yawk" City
JoeyNick is offline   Reply With Quote
Old 06-07-2007, 10:33 AM   #2
Buji's Avatar
holy mackeral....
-Buji
_________________________
Modified EB-22 with Penthouse Top
https://www.sportsmobileforum.com/alb...43791a54be.jpg
Buji is offline   Reply With Quote
Old 06-10-2007, 09:17 PM   #3
Jammyauto's Avatar
Taking the body off the frame is not as bad as is looks. If you look under the E350 you will see that it is all set up for this. Disconnects at the e-brake cable, Central wiring harness disconnects etc. About 8 body to frame mounts, couple electrical connectors, steering colmn then off ya go. About 12 hours work round trip. I have not done an e350 but I have done a Escalde frame replacement. Still hope it's not my van but I do know a SMB owner that has had to have the body off to reseal the oil pan gasket. Good reason to buy the extended warranty.
Seth Hatfield
'05 EB350 6.0 4x4
Homebuilt Interior
Santa Barbara Ca
Jammyauto is offline   Reply With Quote
Old 02-20-2018, 03:22 PM   #4
gahamby's Avatar
The kink wouldn't open. Does the fuel tank ride with the body or stay on the frame? I was thinking about the fuel fill pipe.
'07 GMC 2500 6.0
Old 02-20-2018, 06:10 PM   #5
Holy Thread Revival! Almost a full 10 years since someone had posted in this thread.
Old 02-20-2018, 06:39 PM   #6
gahamby's Avatar
Oops, totally missed the post date. Now I'm trying to remember how I tripped over this thread to start with.
'07 GMC 2500 6.0
Old 02-20-2018, 07:31 PM   #7
No worries, still a very valid question and it shows you did some searching. Some deep, deep searching.
Old 02-21-2018, 10:02 AM   #8
djbonsu's Avatar
The fuel tank stays with the frame. I believe the fuel fill hose can stay with the body or the tank/frame.
2000 E350 Cargo PSD w/ UJOR 6" Lift
djbonsu is offline   Reply With Quote
Old 02-21-2018, 11:04 AM   #9
gnty's Avatar
Part of the filler neck stays with body while the hose stays with the tanks. See attached pics.
We've done it a number of times. As long as you have access to the body bolts (many camper conversions have a sub floor and cabinets covering them) its pretty slick.
gnty is offline   Reply With Quote
Old 02-22-2018, 11:17 AM   #10
Those pictures make it look deceptively easy...
Teutonics is offline   Reply With Quote
