Old 01-31-2019, 08:29 AM   #1
BrianW's Avatar
Chevy truck wheels on Ford E250?
For you wheel gurus out there: any idea if I'll have any problems putting wheels from a 2004 Chevy Silverado 2500 on a 2002 Ford E250? The bolt patterns are the same (8x6.5), but the offset and hub bore looks to be a bit different (although I can't seem to find a definitive reference to the Ford offset).
Here are the specs for the Chevy wheel:
  • Size: 16x6.5
  • Bolt Pattern: 8-6.5"
  • Offset: 28mm
  • Hub bore: 124.1
Looks like the OEM Ford is something like this:
10mm offset
124.9 hub bore
So maybe the Chevy wheels won't work because of the smaller hub bore? The offset seems pretty close.
Old 01-31-2019, 10:32 AM   #2
You can machine out the hub bore. My steel dually wheels are from GM (since Ford doesn't make a 17" dually wheel in our bolt pattern).
Old 01-31-2019, 02:45 PM   #3
BrianW's Avatar
Thanks. Sounds like not really worth the hassle then for alloy wheels. A set on sale locally at a good price, but by the time I get them machined...
Old 01-31-2019, 03:34 PM   #4
Your driving privileges has now been suspended.
Peace, Regis
2011 Express 1500
I'm a camper not a glamper
regis101 is offline   Reply With Quote
