Originally Posted by stiggs
Checked the fuses, put the stock radio back in, replaced the headlight switch, everything working except dash light. 2000 E250 bulb(s)?
Are all the instrument illumination lamps out? If yes then there's an issue with the power feed for that circuit leading to or inside the cluster housing. If the heater control pod has lighting then you should have power to the cluster housing too.
If there's some lighting in the cluster its just a lamp or two burned out. Not a huge technically complex repair but the cluster does need to be removed for proper replacement.
Is the cluster & radio trim panel (flat black) one solid piece or in two pieces, a split between the cluster opening and power ports?
