Old 08-23-2018, 11:38 AM   #11
Kibo's Avatar
Originally Posted by 1der View Post
I think you are right on actually after checking our van. I just measured our CCV medium height with top down and it is 59" inside with insulated ceiling and floor. You would get another 7" to 8" with the High top at 18"/19" vs medium top 11". To achieve the 74" you would need to go at least 24" above gutter.
Just to add another data point, my wife and I can stand up inside our Opt Overland pop top and have just a bit of clearance to the finished ceiling. We're both 5'6", and the floor isn't finished yet. I can take measurements if you'd like. Our is an EB; the RB mold is similar but different. We've used a couple of their rental vans and were able to stand up in those as well from memory.
Old 08-24-2018, 05:30 PM   #12
I would look at DIY fiberglass boat kits. I helped a friend build a sail boat. It came out very nice. The techniques could be easily used to build any shape or size top. We fiberglass ed in wood strips for anchor points and reinforced critical areas with carbon fiber. His boat was very smooth and beautiful. The cool thing is that it you wanted to add or take out features over time you could do that. After all, I'm sure fiberline started in a garage or small shop.
Brianf7028 is offline   Reply With Quote
Dodge
lugee
Sportsmobile
Churley
