Old 12-29-2015, 02:34 PM   #1
Driver door issues
97 E350 driver door key will not work. Can lock door inside.
Outside handle is floppy but will open door.
Inside handle is fine
Any idea what parts I need to fix this
hogasm is offline   Reply With Quote
Old 12-29-2015, 05:30 PM   #2
There is a rod inside that comes down from the latch mechanism to the lock cylinder and pops in with a plastic clip. It isn't easy to get to. I recently replaced my broken driver's door handle and this broke in the process, so I'm in the same place you are. You'll need to replace just that clip most likely. I would hope this is still an available Ford part, but not sure. I think your best bet is a Ford dealer parts counter where you can look at a schematic with someone who can figure out that exact part.
Good luck! I'd love to know what you find out, I haven't gotten around to fixing mine yet either since I have keyless entry.
Old 12-29-2015, 07:06 PM   #3
JackTuppVan's Avatar
^^^ I believe this is the part you need . "door lock rod clip" Dorman 703-237 this part was used in many Ford cars and trucks since the 1980s. http://www.dormanproducts.com/p-1226...origin=keyword
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 12-30-2015, 05:07 AM   #4
Is the key not turning the lock cylinder or does it turn but not lock/unlock the door latch?
If its the latter there indeed may be a lock rod issue or the latch mechanism has issues all its own.
If its the former a new lock cylinder might be in order OR using a good lube like Liquid Wrench or Tri-Flow might restore its function. (Liquid Wrench leaves a bit of lithium lube on the parts, typically I'd use something like PB Blaster or WD-40)
Jack and Scotty are correct and very helpful with their advice---I'm just preparing you for the worse case scenario.
BTW I'm in the auto/truck glass biz!
Old 12-30-2015, 05:21 AM   #5
Will be pulling things apart today between rain drops....have the boat in a thousand pieces taking up the whole garage....
While turning the key there is resistance with only slight movement of the
of the interior lock rod
Now my left rear door lower cable broke...can't win from loosing
Old 12-30-2015, 06:36 AM   #6
Haven't used these guys, but I have their page bookmarked.
http://www.clipsandfasteners.com/default.asp
Old 12-30-2015, 07:36 AM   #7
Those guys are top notch---I use them quite frequently.
Originally Posted by hogasm View Post
At your van's year could be just old age showing itself.
of the interior lock rod.
If the key is hard to turn that tends to point towards the lock cylinder. If it seems to be binding that points to the door latch itself. Squirting the Liquid Wrench inside the latch from the outside of the door might help---might have to remove the latch mechanism and try lube-ing it before re-installing.
Disconnect the lock cylinder rod, test the cylinder with a known good key---if it turns freely we're back to the latch.
A WAG tells me the latch is at fault here, at least the portion where the key cylinder is involved.
If the handle is floppy it might be a good time to replace it---they're available from Dorman etc but I prefer OEM which might be a bit more money. eBay may have a few new OEM parts available for less than dealership so that's worth a try too.
I believe the rear driver's side cables are available separately. Let me know if you need help with specific parts.
Old 12-30-2015, 09:37 AM   #8
Jack and JWA, as always you've come through with solid advice. Here's a link to that clip, also on Amazon for $20. Not cheap for a piece of plastic but if you need a working door lock........
http://www.ebay.com/sch/i.html?_from...03237&_sacat=0
Sorry to hijack.
I agree with above advice, your issue may be the lock itself. Mine spins freely I think, but I know mine is the clip.
Old 12-30-2015, 09:40 AM   #9
Cheapest I can find it.
http://autoplicity.com/3232359-dorma...2RAaArI58P8HAQ
Old 12-30-2015, 09:56 AM   #10
Sorry to hijack.
Thank ya Sir and pish posh on the hijacking----advice that's helpful is never that or a derailing either!
That's one healthy price on a single clip---I'd look here too: http://www.clipsandfasteners.com----they should have them too for a lot less.
Also call Ford to see if they sell them individually----for less than $20 each.
