Old 12-12-2018, 10:21 PM   #11
1der's Avatar
Saline - another little note on the pre tensioners and Air Bag lights.
The code that flashes on the dash may be the first of several if there is more than one fault. It flashes one code until that is cleared, then if there is another fault it will flash the code for that second fault. If you use a more sophisticated code reader that read the air bag codes it will show the multiple codes.
As you noted there are different pretensioners, so be careful to use the exact part number to replace otherwise the belt latch may not engage and the connectors may not be the same.
Old 12-12-2018, 11:22 PM   #12
Yes, I finally found the wires under the carpet with the mate connector cut off.
So I got a replacement connector from the junk yard.
Connected the wires and it all works good with no SRS light blinking.
Thanks all.
caortizemail is offline   Reply With Quote
Old 01-16-2019, 11:38 AM   #13
2006 E350 Pleasure Way Passenger's side seat belt problem.
Warning Light is blinking 3 blinks space 3 blinks. OBD code is B1881.
Want to check continuity of wires from pretensioner.
Where does the connector that goes into the floor end up ?
AndyB is offline   Reply With Quote
Old 01-16-2019, 12:53 PM   #14
Andy
I found the wiring goes from under the passenger seat behind it along to the driver side rear of seat to the B pillar.
