There is a harness that runs from B pillar to B pillar aft of the front seats. Normally right under the carpet seam in that same area. From that harness there is a wire with the mating connector that runs forward under the carpetto to a slit in the carpet or mat where it pops out under the seat base in the middle area of the pedestal.
If the light JWA mentions is not illuminated on the dash, then someone may have messed with the light. If the light is illuminated and does not go out after you have connected that wire, then there are a few other components that may have failed. Let’s see what happens after the connector is reconnected.
