Carringb. Off subject, I see you in Corvallis,or. Funny I might be in your area soon. Looking at a 61 Falcon wagon in Toledo. Wish I had a hitch on the van so I could just go get it. Gotta use the wife's truck so planning it out.
Also is a 2011 bolt pattern a Chevy pattern wheel?
All E-series have the same bolt pattern as Chevy trucks thru 2010 and all chevy vans. But the Chevy trucks and vans have smaller hubs. 2011 Chevy trucks went to an 8x180mm pattern.
I've looked into two options, the kit from Maxx-Lift or replacing the front springs with longer Moogs.
Ramsey from Agile suggested the Moogs, others have used the Max lift. After I built out my interior the van sits pretty level now, but I need a bit more clearance up front.
This is for a 2wd E350.
Which moog springs did u get?
2002 E250 5.4 4R70W 2wd 3.5 inch lift Pleasure-Way Traverse on 16x8 with 265/75/16's
