Old 01-29-2014, 10:46 PM   #1
AndrewST's Avatar
Factory rear AC / Heater controls ?
On my 2009 van (6.0 diesel) I have the factory rear heater.
The problem is that it blows cold or hot air, I can only adjust the speed of the rear fan not the temperature (on the dashboard).
In the passenger vans, how or what allows the temperature adjustment?
Could there be a missing part or control on mine...
If so, could it be added?
Thanks,
Andrew
Old 01-29-2014, 11:22 PM   #2
1der's Avatar
Re: Factory rear AC / Heater controls ?
Hi Andrew, yep!, welcome to the wonderful world of Ford Van rear air/heat. Probably the same as my 2003. That is it in the back, FULL hot or FULL cold, nothing in between. The temp selector on the dash only controls the front ducting. The rear heat comes out ONLY via the rear floor ducts along the driver' side wall and the cold A/C ONLY via the roof vents. I do not think you are missing any parts. The engineers/designers are missing a few screws though.
Spent a bunch of time researching what I thought was wrong only to find that is the way it was designed. Thought about creating some type of blending duct, but never got around to it. Just living with it.
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
Old 01-29-2014, 11:31 PM   #3
AndrewST's Avatar
Hi Ray,
Thank you for your answer, then I will keep on playing with the speed to adjust the temperature.
My van is a cargo window that is why I asked.
One day I might install a device to be able to regulate...
Andrew
Old 01-29-2014, 11:59 PM   #4
Yup. Turn the selector dial to the right (floor-defrost) rear blows hot. Turn it left (vent-A/C) rear blows cold. Using the fan I find this setup to regulate temperature well 99% of the time.
However, for that 1%.... Well that drove me nuts. That condition is when the seats are all full of passengers, and it's wet outside. I need the defrost to see out the windshield, but the back gets hot and stuffy fast with all 14 seats full (for one 3-hr trip, I had 28 people in the van when Next Adventure's Sprinter blew its transmission near Medford).
When my blend door actuator broke, I ended up retrofitting the blend door with a cable control. It was actually a universal Choke cable kit from NAPA. The knob is along the wall just behind the driver's seat, so I can reach back with my left hand to adjust it. Now, I can have rear A/C and front Defrost!
But, I still cannot blend the air. The blend door is before the evaporator and heater core, and the blend door points towards the air-flow. This means the air-flow shoves it tight in either direction. With my cable control, I can move it into the middle, but once I turn the fan one, it'll blow into one position or the other. To make the door adjustable, it would have to be flipped away from the air direction, and that's just not possible with the factory packaging, which is shaped the way it is so it won't intrude into seat space for row-5. Even with an electronic actuator, I'm pretty sure the blower moves enough CFM it would burn up the actuator unless the door were flipped.
I've though about this some, and I think the best way to have A/C and Heat at the same time is to install two separate fans for each duct, and use those to adjust temperature. But for now I'll stick with my binary cable control.
Reunel rear bumper
Old 01-30-2014, 09:59 AM   #5
AndrewST's Avatar
Thank you Carringb.
