Old 03-10-2010, 11:06 AM   #11
Re: Ford 2wd lift kit?
Originally Posted by LeadDoggy
You got Advance Trac RSC?
One of the guys asked me that too. I don't think I have it. There would be a button on my dash right?
2010 EB E-250 2wd Homebrew
Transformer style build w/AV lift!
floorguy_724 is offline   Reply With Quote
Old 03-10-2010, 11:30 AM   #12
LeadDoggy's Avatar
Correct and there would be sign on rear left door.
I believe that it is standard on passerger van and not usually on cargo.
Both Action Van and J Flame know that Advance Trac RSC is a problem on their lifts and both know me as for I have talked with them about the possible cures.
07 E350, Custom and Lifted
98 Harley Davidson Classic
09 KTM EXC 450
Old 03-10-2010, 11:40 AM   #13
floorguy_724 wrote:LeadDoggy wrote:You got Advance Trac RSC?
Thanks Lead! How is the ride on the AV? Your van looks awesome and I am doing for looks and will go the 4x4 route in a few years.
Old 03-10-2010, 01:29 PM   #14
So you just push the button to disable the Advance Trac and then everything works fine?
bsdctx is offline   Reply With Quote
Old 03-10-2010, 02:33 PM   #15
Camburg is a NO for me also because of the bending thing.
Both Action Van and J-Flame make good products.
I have Action Van on my 2007 E350. No problems or complaints.
If I would have know about J Flame, I would have gone with them. Their stuff just looks better.
Both kits keep proper geometry and use the same pitnam arm.
Where you from?
I looked at the pics and Action van i-beams didn't look bent, but the kit says it comes with new I-breams so I ASSumed they were modified. Sorry for any confusion if I caused any.
As for the RSC, Ford says it will work it the center of gravity of the van is below 39.2". I think the loading and interior layout can help keep the cG down below that point, even with the lift (depending on how high). I suspect widening the wheel track (adapters or high-backspace wheels) would also keep it from kicking in too early.
Reunel rear bumper
Old 03-10-2010, 02:46 PM   #16
Pushing it once doesn't do what you think... Here's what I've found...
push RSC button and release: braking traction control mode
push and HOLD RSC button for at least 5 seconds: everything off. The "off" light in the button will flash. It might engage if a very high threshold is reached, but luckily I've never had that occur.
4X4 auto and high: does nothing; uses whatever setting the button is in
4X4 low: automatically goes into traction only mode. You can shut this off by holding the button as explained above.
Reunel rear bumper
Old 03-10-2010, 03:00 PM   #17
LeadDoggy's Avatar
Where you from?
Kit comes with radius arms, not I beams. You have to return your stock radius arms because of a core charge.
As for the problems, it is in the turning ratio. The drop pitnam arm is not the same lenght from hole to hole on a verticle. There is a sensor attached to the steering wheel and once you get past 1/4 turn and above 20 mph the Advance starts kicking in.
09 KTM EXC 450
Old 03-10-2010, 03:06 PM   #18
LeadDoggy's Avatar
I read a post of your on another forum regarding your problems with lifting your van and the Advance Trac RSC. What solution did you come up with? Would you recommend finding a van without the A T RSC?
Presently looking for another drop pitnam arm which has the right lenght. Also thinking about modifying the steering wheel sensor activating device. There is a round unit with holes on the steering shaft that the sensor reads. I believe that it counts the hole when you turn the wheel. Thinking I need to cover a hole or two.
At this time, being that I have not yet found a solution, I would not over look a van with Advance Trac RSC.
09 KTM EXC 450
Old 03-10-2010, 06:04 PM   #19
I think changing the pitman arm length could leave you with bump steer.
I think you may be right about changing the steering angle pickup disc. But, covering up holes is probably not the right way. I'm guessing you'd need to just make a new one with the correct hole count, evenly spaced. And I think you need to increase hole count (space closer), since the longer pitman arm means the van turns quicker than with the stock arm, for the same steering wheel angle.
Reunel rear bumper
Old 03-10-2010, 08:47 PM   #20
UJOINT's Avatar
Consider a partial 4x4 conversion before pulling the trigger on a 2wd lift. For about the same cost, you can have a front axle under the van, and complete the rest of the swap later. (t-case/etc)
Chris Steuber
02 E350 7.3 (V4)
05 E350 V10 (V7)
17 Focus RS,90 SHO,49 Willy CJ2A
ujointoffroad.com
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
