Originally Posted by dhally
I have found that some of the "super-duper" wipers don't work as well as the OEM or cheap anco ones. Sometimes it is aerodynamics - the airflow lifts the arm.
Maybe just try a different blade?
Another great point---the "super duper" versions tend to be over-priced crap that barely work at all. Most likely those buying them do so to hopefully correct this situation, most probably also disappointed they're not as hyped.
I buy the OEM style, typically $10 or less each and don't expect them to remain effective past 4-6 months maximum. Ford's version seem to have slightly larger blades, are light in weight and worked very well for me over the past 7-8 years.
Your climate greatly affects wiper blade life too---not that you didn't already know that!
