With an open differential, no locker, no 'limited slip differential' (LSD), you don't get very many flats so the 245 is 'emergency use', if you want to save a couple bucks you can just keep the 245. But you'll have to first confirm that you have an open, or LSD differential (outlined above).
Running two different diameters tires in the rear until you can get to a tire store to repair the flat one, won't hurt the moving parts within an 'open differential'. Heck, with the reserve strength of a Dana 60 or Sterling 10.25, it's not worth worrying about. The difference in side gear and differential carrier wear (between same size, and different size rear tires) is negligible, as these parts smoothly slide and move with every curve, by design. You never notice the diff ;-) Two different size rear tires on an open diff behaves like you are driving through along slow cure, while you are going in a straight line. The oil temp in the diff might go up slightly, but you'll never feel it in the drive train.
Doing that with a factory Limited Slip Diff (with clutch plates) is a completely different story, as that will prematurely wear the differential's clutch plates. It won't leave you stranded, but it will turn it into an open differential until you repair it. The same is true if you have an aftermarket loc-rite locker, also referred to as a 'lunch-box locker' (like I do). Two different size rear tires makes the locker wind up, then release (ratchet or tooth skipping noise), constantly, as you are driving in a straight line. It's kinda hard on the $300 locker unit. But again, you can do it in a pinch, to get you to a tire store.
