Old 09-12-2016, 11:19 AM   #21
That's the one! (although I have an older can before they changed the name to "chain saver")
Teutonics is offline   Reply With Quote
Old 06-18-2017, 08:02 AM   #22
Originally Posted by tlg View Post
I had the same problem. Turned out the leaf spring bushings were bad. Squeak went away when those were replaced. Luckily, was still under warranty. I thought it was the sway bar bushings but those were ok.
Follow up: This ^^^ seems to be the problem. The squeak came back a couple of weeks ago. This time I sprayed only the spring shackle bushings and the squeak went away. I'm not sure if it's worth the effort of replacing the shackles/bushings if I can just spray them every 6-9 months.
Silver Streak
Glider
Dusty
capnkurt
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
