Originally Posted by tlg
I had the same problem. Turned out the leaf spring bushings were bad. Squeak went away when those were replaced. Luckily, was still under warranty. I thought it was the sway bar bushings but those were ok.
Follow up: This ^^^ seems to be the problem. The squeak came back a couple of weeks ago. This time I sprayed only the spring shackle bushings and the squeak went away. I'm not sure if it's worth the effort of replacing the shackles/bushings if I can just spray them every 6-9 months.
