Old 11-08-2019, 05:49 PM   #11
shenrie's Avatar
I use whatever spray lube I can find. Wd40, silicone spray, lps, and regular oil, they all seem to work about the same for me.
I spray the top and bottom of the bar. The checks on rear doors usually need to be wiped down though. The dust from dirt roads really accumulates bad on them.
Old 11-08-2019, 10:10 PM   #12
White lithium grease (aerosol) seems to be the only lube that's able to make that nasty screetching and popping of my crusty door hinges go away, so that's what I'd recommend.
P.S. sorry I tried to suggest a hooskerdont when you clearly asked for a whatchamacallit.
Old 11-09-2019, 06:16 AM   #13
X2 on lithium
