Old 02-12-2019, 11:51 AM   #1
How much can you lift via springs without new radius arms or i beams?
How much of a lift can you put on a 2006 e-250 before you need new radius arms and i-beams?
prcrawford is offline   Reply With Quote
Old 02-12-2019, 12:51 PM   #2
With a 2" coil spacer, I had to just about max out a set of double-eccentric alignment cams (4°?) to get my camber back to 0°. I'd imagine that about 2 1/2" is about the limit while still maintaining acceptable camber/caster, using readily available alignment cams. That being said, I have seen a few guys stuff 4" lift coils in their E-vans, but I wouldn't recommend that.
Old 03-27-2019, 01:05 AM   #3
Typically 1.5 maybe 2" if your lucky and you will most likely need to clearance you I-beam so your spindle doesn't rub. This will also steal most of your caster.
This is a lot cheaper option then the Ocotillo Cruiser lift which would be your best bet if the price is in your budget.
https://weldtecdesigns.com/product/1...tillo-cruiser/
Let me know if you have additional questions.
WeldTecDesigns is offline   Reply With Quote
Rosy
Isever
BigRed4x4
BigRed4x4
