Old 06-28-2012, 04:09 PM   #11
BIGVANS's Avatar
Re: How to remove air vent blades (Ford)
Perfect timing for the pictures!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 03-19-2017, 06:39 PM   #12
Youngster's Avatar
Originally Posted by WVvan View Post
Gently pry up at the bottom of the air vent with a flat blade screwdriver.
Pops right out.
NOTE: You don't have to remove the front of the dash to do this. It just happened to be on my workbench at the moment.
This worked great for me, for the center vents, thank you.
However, the far side dash vents next the the front doors are different and don't seem to want to pry out. Anyone have a trick to get these out without removing the dash?
2016 Beta 500 RS
2014 KTM 350 EXC-F
Youngster is offline   Reply With Quote
Old 03-19-2017, 07:06 PM   #13
I learned my lesson (more than once) about not using metal tools to remove plastic interior parts .
I've had much better luck with hard nylon plastic pry tools, like in the link below. No gouging of the interior plastic body parts.
