12-19-2010, 08:34 PM
Re: Installing new tow mirrors on a 2002 e350
From what I see, you might have to drill more holes and add longer bolts to the mirror so they come through both sides instead of having access holes, sounds like it depends on your door as much as your year but the outside should fit if you can make the holes.
I have yet to start my mirror project and my van is newer, so I'm trying to interpret what's shown in this thread too.
12-20-2010, 02:00 PM
Ok, no difference in the mirrors 2002 and 1997... Thanks...
E150 4x4 1986
E350 4x4 1997
Russian name road that place where are going to pass...
12-30-2010, 03:54 AM
Originally Posted by van350sd
I am about to install a new set of 2009 E550 Tow Mirrors on my 2000 E350 Extended Van Explorer Conversion Interior 7.3L Mobile Living Room. My van is all powered so the switch is there, I may need to change the plug. I know there is some drilling involved. The 2009 E550 Mirror Numbers are,
LEFT - 7C2417683CA5YGY ( 1446583 )
RIGHT -7C2417682CA5YGY ( 1446582 )
Some people said they cut-off one of the studs. I will leave all the studs on the mirror and drill away.
Best,
Russ
Russ, did you ever get these installed and if so, any problems?
Terry
4WP - Temecula CA
Shopping for the next rig...
12-30-2010, 08:44 AM
Da Comrade. The entire body has not changed much since 1992.
02-01-2011, 05:25 AM
Good day, Gents. I wanted to do the opposite, and put the smaller mirrors on mine. Does anyone want to trade a set of mirrors? I have the Tow mirrors but wanted to put the small double mirrors that comes on the 07. Mine are mint as my van only has 18k on it.
02-01-2011, 08:01 AM
I'll have a set once I upgrade mine, I'd certainly trade for the tow mirrors. "Once" means when it's warm enough to take apart the doors. If not I'll be selling them anyway.
02-01-2011, 09:35 AM
I've got a set off my 07, Mint also, you are welcome to trade. Where are you located.
PM Sent
Paul
02-01-2011, 10:16 AM
Yeah, trade Paul- his are already off. Plus he got me the tow-mirrors in the first place, and he will make MUCH better use of them.
02-15-2011, 05:09 AM
I put them on my 99 and had to make hols bigger and drill on new hole just below door panel. And I just put them on my 2003 and those bolt right on no drilling . You have to pull the door panels for the 4th bottom hole.
11-26-2011, 04:06 PM
#20
I got some 2005 power mirrors with blind spot mirror, not towing ones, to fit on my 2002 and I have the same issue. (2002 is 3 small holes, only 2 line up with 4 larger mounts on 2005 mirrors)
It looks like there is a big structural bracket where the 2nd top hole would go.
Also the power connector are different. I don't really want to cut the connectors off the old mirrors, I was hoping someone could re-use them.
Sportsmobile-less.
