Old 01-09-2020, 01:29 PM   #41
if you want black M-1, check here - https://www.greenbuildingsupply.com/...hesive-Sealant
They're a dollar more and charge for shipping...
Greenbuildingsupply also has other sealants/adhesives that may work, but color choice is more limited...e.g. AFM Safecoat as a 500psi+ shear strength.
I bought some gray from concreteexchange and have not used it yet.
FYI - acetone works great for cleanup of M-1.
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 01-10-2020, 02:58 PM   #42
It looks like the shipping is pretty steep with them. How does Dow Corning 732 look? They have it in black and clear on Amazon, and it seems like it'll do the trick. I'd prefer black M-1…if it wasn't out of stock at that first place you linked.
Sigg is offline   Reply With Quote
Old 01-10-2020, 06:03 PM   #43
BrianW's Avatar
I’m sure the fancy tube stuff is good, but butyl tape is cheap and available many places. And based on door windows I’ve removed at junkyards, holds up really well even many years later. Has worked well on my installs so far, too.
Old 01-13-2020, 04:12 AM   #44
I would agree but would add the butyl tape does have a bit of learning curve to its use. From removing the old to placing the new and tightening the bolts to NOT break the glass does take a bit of super excessive carefullness.
And there's no need to over-think or over-spend on the tube stuff---typical exterior grade silicone adhesive/sealant from Lowe's, Home Depot etc etc works very well too--its what I've used a lot of times.
HTH
Old 01-15-2020, 06:34 PM   #45
Houstonredrider's Avatar
I used black RTV silicone on my pop out windows. About a year ago. So far so good and easy to apply. I believe I followed JWA advice on one of the numerous forums he participates.
2010 E350 4x4 MG Coil conversion
Houstonredrider is offline   Reply With Quote
Old 01-16-2020, 03:51 AM   #46
I also contribute to Ford Truck Enthusiasts aka FTE.
Frankly I like this site far far better as there are far far more people posting questions about how-to's BEFORE the dig into something and make a complete mess of things "thinking" they know what they're doing.
Old 01-16-2020, 01:54 PM   #47
I used butyl tape without issue. It can be a bit of a pain to deal with since it's so gummy. It does seal very well though.
2002 E-350 7.3L PSD Sportsmobile Poptop
1992 E-150 4.9L Sportsmobile [sold]
Turbo is offline   Reply With Quote
