Old 04-03-2017, 07:13 AM   #1
IrishAl's Avatar
Leaking E350 Rear Window
So I have what I believe to be a leaking rear passenger side window. In reading other threads, this is common on the E350's (mine's a 97). I've got the roof seams well sealed and trying to figure out the best way to seal that rear window. When it rains, the headliner is wet in a perfect line along the top right at the window edge.
Should I just silicone caulk the crap out of it, or take it somewhere?
Cheers.
Alan
IrishAl is offline   Reply With Quote
Old 04-03-2017, 09:46 AM   #2
Flux's Avatar
It's not particularly hard to pull a window, clean it up, and put new a new butyl seal on it. Probably 40 bucks for the butyl and the tool and two hours to do the job.
<br>
Old 04-03-2017, 12:31 PM   #3
IrishAl's Avatar
Thx Flux!! Might give that a try!
Old 04-03-2017, 12:40 PM   #4
Flux's Avatar
Get yourself one of these:
http://static.speedwaymotors.com/RS/...91089434_L.jpg
take off all the bolts except for a few at the top, but loosen those so you don't accidentally pop the window. Cut between the plastic frame and the van body in between the bolts all the way around. It'll give, then just kind of pry it off. Clean up all the butyl on the van body and off the frame and then replace with new butyl. One trick I learned is to leave the butyl round around the bolts and smoosh it flat a bit between the bolts. It will give you a better fit when you reinstall. The bolts will smash the butyl right around them.
Put it in place and then tighten the bolts to snuggish. Do it incrimentally around and around so as to get and even seal.
I just replaced three windows I messed up and put in rear popouts. It's not so bad. 3M window weld is what I got. good stuff.
<br>
Old 04-03-2017, 02:21 PM   #5
Bbasso's Avatar
I hate to disagree but no tools are needed to remove any of the door glass. Just push very slowly and the butyl tape will break free.
Rob.
Current:
And had three other E350s...
Old 04-03-2017, 02:53 PM   #6
Flux's Avatar
Or try pushing slowly and no tool!
<br>
Old 04-04-2017, 06:20 AM   #7
So, should we smoosh or smash? The other day I was trying to decide whether to squish or squash. I wonder how many, ummm, words (?) there are for this process?
Currently vanless. Weird.
Old 04-04-2017, 07:25 AM   #8
Bbasso's Avatar
How about squish?
Rob.
Current:
Old 04-04-2017, 08:53 AM   #9
Flux's Avatar
Mine smooshed.....I'm sticking to that......no pun intended....at first.
<br>
Old 04-04-2017, 10:00 AM   #10
It's a tricky business. You've got to hold your mouth right while smooshing. No pun intended there either.
