Originally Posted by Bellpilot
Here is link to a YouTube video of the process I basically did, hope this helps.
Did this on all my Excursion doors years ago. Definitely seals better and also helps reduce dust intrusion. You may have to slam the doors a bit harder because of the increased seal stiffness.
BTW, try not to let the tubing touch the ground as you insert it because it will pick up dirt and debris. At least it did for me (used silicone tubing which is a bit more sticky).
