Old 12-30-2018, 12:21 PM   #1
Lifting a 2WD Dodge B350 Van
I have a 1996 2WD Standard Wheelbase Dodge B350 "Sportsmobile" pop top conversion van. Given that this van is 2WD and that Dodge Vans are Unibody in construction leads to my question:
Is there a good and safe way to "Lift" this 2WD van 2 inches to 3 inches MAX over stock suspension height without major surgery or goofy suspension angles?
vintageracer is offline   Reply With Quote
Old 12-30-2018, 09:02 PM   #2
Pntyrmvr's Avatar
Yup. Find the article on lowering Dodge pickups and reverse it. The pickups have higher height steering knuckles than the vans. The old lowering trick for the pickups is a raising trick for the vans.
Old 01-03-2019, 08:33 AM   #3
It's not the spindle that adds height it's the lower control arm. The PU lower control arm has a 2-3 inch higher position for the spring versus the van lower control arm which is 2-3 inches lower in the control.
Remember "Drive Fast, Turn Heads, Break Hearts!"
2001 Chevrolet Express 3500 Quigley 4WD ATF "Bomber Van"
1995 Chevrolet ASSTRO 4WD Quigley Custom Van
1994 Dodge B350 Sportsmobile Van
Old 07-28-2019, 05:04 PM   #4
have you found any more info. on this?
greasemonkey512 is offline   Reply With Quote
Old 08-29-2019, 09:48 PM   #5
I’m interested also, I was planning on using a 3” eurothane bushing on top of the spring, hope to get 2” -3” lift
Sheppie62 is offline   Reply With Quote
Old 08-30-2019, 06:30 PM   #6
U Tube video (part 1 of 18) on how to lift a Dodge RAM van, as part of a full front end project. Been thinking about lifting mine.
https://www.bing.com/videos/search?q...il&FORM=VIREHT
2002 Dodge B350 5.9L RB50 Penthouse "Hippie Van 2.0"
hippievan is offline   Reply With Quote
