Re: Lower dash panel removal?
You may need to pull the corners from the back side to keep from breaking the tabs off. Then putting it back on you may need to align the bottom ones with your fingers before it will snap in.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
