Old 04-30-2012, 11:17 AM   #1
Lower dash panel removal?
On a 2005 E-350 I want to remove the lower dash panel. This is the one under the steering wheel.
I want to get a good look at some switches/wiring that is on or behind that panel.
Thanks
TraceyAZ
2005 Ford E-350 SMB 4x4
6.0 EB 50 floor plan. sold :(
TraceyAZ is offline   Reply With Quote
Old 04-30-2012, 11:46 AM   #2
Ultrasport12's Avatar
Re: Lower dash panel removal?
It just pulls straight off towards the rear of the van... It has four sring clips that hold it on.
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 04-30-2012, 11:54 AM   #3
Thank you Ultrasport12 I will give it a try.
TraceyAZ
Old 04-30-2012, 01:33 PM   #4
BIGVANS's Avatar
You may need to pull the corners from the back side to keep from breaking the tabs off. Then putting it back on you may need to align the bottom ones with your fingers before it will snap in.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 04-30-2012, 10:31 PM   #5
I was able to remove and find the issue I was looking for. Fixed a simple wire that came off its terminal and all was well.
Thank you for your help.
TraceyAZ
