Old 09-01-2019, 01:23 PM   #1
Metal Edge trim?
I bought a 2006 chevy express van with a turtle on top and am stripping out the interior. Any suggestions on what i can use on the sharp steel edges in the roof that was cut out? I dont want to put a fabric interior back in. Hoping to find some kind of rubberized seal made for this area, so that people dont get cut.
Hopster is offline   Reply With Quote
Old 09-01-2019, 08:39 PM   #2
Search "rubber edge trim for sheet metal" on Amazon
1998 E350 7.3 Hightop
r27d is offline   Reply With Quote
Old 09-01-2019, 08:49 PM   #3
Well that was too easy- thanks
Old 09-02-2019, 08:24 AM   #4
Also search on Mcmaster.com There will lots of material choices (interior/exterior rated) shapes and cross sections for specific metal thicknesses.
You buy it by the foot...
Old 09-03-2019, 04:26 AM   #5
Last time I bought that material from McMaster it was available only in 50' rolls---hopefully that's changed since then.
I found some in White that fit my material thickness and height when installed. Not the highest of quality but for interior use it was perfect--fairly priced too. Find it here: https://www.ebay.com/itm/Door-Hood-T...72.m2749.l2649
HTH
Old 09-03-2019, 06:06 AM   #6
It takes a lot more than you think to do a perimeter around something like this, if I'm understanding the OP. Think about a 20' long van. The cut may be 15' on each side and nearly 6' across. There's 42' right there.
Old 09-03-2019, 08:05 AM   #7
Here are a few choices...available in 10, 25, 50 and 100 foot lengths...
https://www.mcmaster.com/epdm-rubber-edge-trim
https://www.mcmaster.com/neoprene-rubber-edge-trim
https://www.mcmaster.com/sbr-rubber-edge-trim
https://www.mcmaster.com/edging
Old 09-08-2019, 04:39 AM   #8
Thanks everyone. It turned out great
