Old 08-11-2014, 01:00 AM   #11
Re: Need New Front Brake Rotors
The new larger 2wd rotors fit 16" steel wheels and 16" Ford OEM alloy wheels. Some 16" aftermarket alloys will not fit.
Reunel rear bumper
Old 08-11-2014, 04:09 AM   #12
Originally Posted by BrianW
Or upgrade to 2008 or newer brakes. Search the forum for several threads on this. Pretty easy and not that terribly expensive all things considered.
Here's some info on this very topic: http://www.sportsmobileforum.com/vie...p?f=39&t=12224
Old 08-11-2014, 07:18 AM   #13
ANZAC's Avatar
Originally Posted by REF
What year is your rig? Someone correct me if I'm wrong, but if your wheels are currently 16", swapping to newer brake bits would mean having to swap over to 17" wheels to make the clearance for the larger rotors, I went with frozen rotors slotted/cryo up front with the hawk pads all around, had a local machine shop drill them out to 8X6.5, nice upgrade. I guess a few ways to go....
Note that the rotor part numbers I posted above don't need to be drilled out (2WD obviously).
Sportsmobile-less.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
