Old 08-08-2014, 01:44 PM   #1
stiggs's Avatar
Send a message via ICQ to stiggs Send a message via AIM to stiggs
Need New Front Brake Rotors
I have a slight warp in my front rotors, anyone have a suggestion for a better cooling rotor?
2000 Ford RB30 PH 2WD -- Eagle Rock California
stiggs is offline   Reply With Quote
Old 08-08-2014, 03:29 PM   #2
Re: Need New Front Brake Rotors
Are you sure the rotor is warped? Is it a pulsation in the pedal while stopping, or you measured a warped rotor?
If you measured a warped rotor (i.e. runout = 0.015") replace them.
If it is a pulsation in the pedal it is more likely brake pad deposits on the disc. This happens with heavy brake use and then stopping with the pad in one place on the disc. Due to the heat, some transfer of material from the pad to the disc can occur. If that happens you can take some 400-1000 grit Wet/Dry sandpaper and thoroughly sand the disc to remove the pad material that you can neither see nor feel.
I try to use the least brake I can, relying on compression braking and downshifting as much as possible. And iff I have hot brakes and get stuck at a light, I use the parking brake and release the service brakes.
Old 08-08-2014, 03:38 PM   #3
stiggs's Avatar
Thanks Mike,
Yea i am getting a pulsating, I have been commuting lately so lots of stop and go traffic. Seems to pulsate at low speed. Ill try your suggestion
Old 08-10-2014, 09:02 AM   #4
ANZAC's Avatar
On my empty 2WD 99 cargo van I installed cryo treated slotted rotors and Hawk LTS brake pads.
For your rig:
Hawk LTS pads p/n HB334Y.736
Stoptech Slotted/cryo left rotor 126.65046CSL
Stoptech Slotted/cryo righ rotor 126.65046CSR
or
Stoptech Slotted (no cryo) left rotor 126.65046SL
Stoptech Slotted (no cryo) right rotor 126.65046SR
I put in new wheel bearings and synthetic grease while I was there.
Slotted rotors help remove gas build up under heavy braking.
Cryo treatment helps reduce cracks due to heat.
Made a huge difference, I used to tow up and down this very steep twisty hill for several miles. After this upgrade the brakes were as good at the bottom as when I started at the top.
All the above available at TireRack.com.
Sportsmobile-less.
Old 08-10-2014, 05:23 PM   #5
BrianW's Avatar
Or upgrade to 2008 or newer brakes. Search the forum for several threads on this. Pretty easy and not that terribly expensive all things considered.
Old 08-10-2014, 07:23 PM   #6
ANZAC's Avatar
Aren't they 8 x 170?
Sportsmobile-less.
Old 08-10-2014, 08:44 PM   #7
BajaSportsmobile's Avatar
No. All E Series are 8 on 6.5.
I have take off bits from a 2014 with 1,200 miles on them available.
AgileOffRoad.com
Old 08-10-2014, 11:53 PM   #8
ANZAC's Avatar
Do they require a larger wheel?
Sportsmobile-less.
Old 08-10-2014, 11:59 PM   #9
REF
REF's Avatar
Send a message via MSN to REF
What year is your rig? Someone correct me if I'm wrong, but if your wheels are currently 16", swapping to newer brake bits would mean having to swap over to 17" wheels to make the clearance for the larger rotors, I went with frozen rotors slotted/cryo up front with the hawk pads all around, had a local machine shop drill them out to 8X6.5, nice upgrade. I guess a few ways to go....
Old 08-11-2014, 12:58 AM   #10
Ford has always delivered the E Series with 16" wheels. Bigger rotors, bigger calipers, bigger pads - same wheels.
AgileOffRoad.com
Biggie
Berta
AWOL
Twoxentrix
