Old 04-08-2008, 01:39 PM   #1
Oddball Latch/rear Door
I had thought this to be a Ford part, but they deny it. On my 2007 E350, rear driver side door sill, to the left of the main door latch is a 2 prong plastic fitting. On the door itself, on the bottom, is a corresponding, plastic attachment, which engages the one on the sill when closed.
What is it?
07 E-350
patrick51 is offline   Reply With Quote
Old 04-09-2008, 08:14 AM   #2
yvrr's Avatar
Is that the access opening cover for lowering the spare tire?
Jack
'01 Ford EB50p Quigley 4WD
Old 04-09-2008, 11:09 AM   #3
Oddball latch/rear door
On the vinyl trim which runs the width of the van is a rubber cover, which I was told was some type of access hole for the previous spare tire. I have the under floor compartment. So this pastic oddball ftg. is on the metal sill. Thanks
07 E-350
Old 04-09-2008, 11:21 AM   #4
alta825's Avatar
I believe it is the 'lock' for lowering the spare. W/O removing it you can't lower the spare if it is underneath. At least that is what my 01 has....
-d
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 04-09-2008, 12:11 PM   #5
-d
Yea I got that also at the bottom of the door. It kind of sits there and rattles around, never sits in the rubber seal and provides a spot for dust to help find its way in. I was told the same by SMB...it's for the spare tire that is no longer there.
Old 04-09-2008, 12:21 PM   #6
Oddball Latch/rear door
It is "funny", the dealer's don't seem to know anything about this! The standard answer for all of the "know nothings" is, " You'll have to check with those who did the conversion".
07 E-350
Old 04-09-2008, 06:57 PM   #7
I was able to turn out the latch screw on the door sill and remove the metal plate underneath, and it may be a support arm for the tool to lower the spare tire before removed for the underfloor storage. The spring loaded matching piece on the door itself is still a mystery as it does not appear to have any wiring, or purpose to it.
07 E-350
Old 04-10-2008, 12:49 AM   #8
rear door latch
Patrick,
The metal plate you removed is a "lock" for the original factory spare tire. It can only be removed to access the lowering unit if the rear doors are opened. You'll want to replace it, along with the rubber grommet around it, to prevent even more dust from entering through the back door area.
The spring loaded piece is there to help "center" the door in the jamb so that the curb side door aligns with the driver side door. It also aids in keeping the door latches from getting in a bind when the body is twisted, as it will in certain situations.
John K.
John Kalmbach is offline   Reply With Quote
Old 04-10-2008, 05:27 AM   #9
Aaahaaa! Mystery solved Sherlock! Thanks John K. A good tip about sealing for dust, thanks. Hopefully, before long, with spring on the way, we will be out "twisting" the SMB. Now, to find a use for the old metal tirelock on the SMB, in a true miserly camper style . A coat hook possibly.
Thanks again.
07 E-350
