Old 08-06-2018, 04:16 AM   #11
Originally Posted by MountainBikeRoamer View Post
Since you're having success --- can you share some info on the u-nuts/speed-nuts hardware that you're picking up to mount those running boards? I've been sitting on a set of those same OEM boards for probably a year or so, and the project of mounting them has stalled (mostly) because they came without the mounting hardware.
Look to any online or local auto body hardware supply outfit---typically the AuVeCo brand has an extensive selection of extruded u-nuts etc. I use this outfit regularly, might be a good starting point: ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
HTH
Tags
oem, running boards
