more progress.....got the brush guard tubes welded......
I found a guy locally who is a talented welder, and I had him TIG weld the tubing....much nicer than MIG.....
I'm now making all the final little doo-dads like delrin ramps for the swingarms and swingarm travel stops and brackets to tie the swingarm support structure to the upper door hinges....getting close to the end.
Weather sealing the top access hatch is also a bit of a challenge yet to come, and finally powder coating everything. The welder had some good input for powder coating; ask for UV resistant powder coat.
I have a swingarm tray and small swingarm box purchased from other members here, and I am toying with the idea of building a structure between them....mocked up in the pic by the 5 gallon bucket and cardboard box....the closed box is not as wide as the tray by a couple of inches.....
At the moment I'm leaning toward just using the closed box with the rails on top.
I'm also planning on a rear vertical piece of aluminum sheet on the passenger swingarm to mount a rotopax behind; this will drive relocating my license plate. I picked up a couple of tiny LEDs suitable for illuminating the plate once it's final home is determined.
