Old 04-14-2019, 08:41 AM   #1
replace hinge pins e-series?
My doors are drooping enough to make shutting them a but awkward. Can I just replace the pins or do the hinges need to be replaced too? Any other tricks to repairing this?
Seattle350 is offline   Reply With Quote
Old 04-16-2019, 07:20 PM   #2
Gooseberry's Avatar
I have seen kits like this that you can rebuild the hinge.
https://shop.advanceautoparts.com/p/...iABEgI4iPD_BwE
Old 04-17-2019, 07:37 AM   #3
The linked kits tend to be for GM hinges which used the bronze bushings---I'm not sure if anything of good quality exists for the Ford E-Series. The problem would be if the leaves of the hinge are worn replacing just the pin would have nearly zero effect or improvement.
New hinges would be my choice but something solid from a scrap yard would be something to look into. They would need to be painted to match but since so little of them extend past the body the Dupli-Color stuff would work great.
Do be advised you'd want the scrap yards parts in a matched upper and lower pair. Ford used two different styles but both would fit the standard body and door shell. Anything from 1992 to EOL should work.
HTH
Old 04-17-2019, 09:01 AM   #4
1der's Avatar
HTH
x2 re: this advice - the Door Talon/Claw for the side doors has two hooks to accommodate the different hinges. The hinges may look the same but they can have different amounts of swing, so matched sets are critical. Some allow the side door to swing much closer to the body.
Old 04-17-2019, 10:02 AM   #5
wadewaydo's Avatar
I used to work for Ford, and they didn't offer any kits, and haven't come across any aftermarket solutions. In my experience the hinges don't wear out as quickly as you might think. Usually the little spring breaks that holds the door open before the pivots wear out. If your door is just sagging, you can adjust the doors on the mounting bolts and striker. If that doesn't work then the shell would be the next place I would look. The shell is much softer than the hinge and can be bent (and bent back). It can stress crack around the hinge mount, as well, and may need to be welded (or plated).
If you can lift the door up when open and it wiggles then the metal is fatigued on the shell, or the hinges are worn out. Then go to the junk yard.
1995 Econoline E-150 Custom Campmobile "Jupiter I" RB, 4wd Dana 60s, 93 Eurovan poptop.
1976 VW Type II Transporter Westfalia Campmobile.
1994 Toyota 4Runner,2001 Ford Escape,1970 Chevy El Camino,2 Cargo Trailers, 5 bikes, 4 Kayaks, 1 Canoe
wadewaydo is offline   Reply With Quote
Old 04-17-2019, 08:26 PM   #6
It's very clear the holes in the hinges are reamed out or the pins have worn down because there is a lot of play in them. If I have to, I'll make bushing with new pins.
Old 04-17-2019, 08:33 PM   #7
Gooseberry's Avatar
Ok this one has the Ford and it has pins with bushings for $11 so might worth a try.
https://www.google.com/aclk?sa=L&ai=...BAgLEAo&adurl=
Old 04-19-2019, 09:55 AM   #8
Those are very much worth the investment in both time and money.
I've never seen those so thanks for finding them and sharing here!
Coddiwomple
Rpence
The Yeti
TexGX
