Old 11-09-2013, 07:15 AM   #11
calebmogul's Avatar
Re: Replacing Bench Seats with Captain chairs
I have a driver's side swivel seat base for sale. It came from discountvans.com. It's fabricated to bolt on a ford factory front seat to the seat base. I can send you some pics if you are interested.
calebmogul
2003 E350 7.3 Turbo Diesel
4" Ujoint 4x4 Conversion
Diamond Eye Exhuast
Dp Tuner
calebmogul is offline   Reply With Quote
Old 11-10-2013, 07:08 PM   #12
Originally Posted by postaldave
what method did you use to mount them? i like the swivel on the on front like that!
did you use the factory seat belt on the front or the seats??
I designed and fabricated mounts to put the seats in the front. None of the aftermarket swivels would work so I made my own.
(picture of the prototype swivel)
I removed the Toyota seat belts and fit the Ford pre-tensioners to the seat to retain the factory belts from the van.
I wrote up a pretty detailed summary of the seats on Expedition Portal a while back to try to answer all of the basic questions about the seats. If you want any more details let me know.
http://www.expeditionportal.com/forum/t ... enna-seats
Old 11-10-2013, 11:51 PM   #13
thanks for the link. thats all the info i really needed. sweet!
postaldave is offline   Reply With Quote
Old 06-07-2017, 11:23 AM   #14
Mgmetalworks. Set up looks awesome. Just curious if you have a write up or instructions on how you mounted the Sienna seats in the back. Do you have any pictures of how they are mounted on the bottom of the van. What types of bolts and plates were used or are they welded on? I am looking at replacing the bench seat with two captains chairs. I am looking at the brackets from U joint and I know that I am going to have to drill some additional holes through the floor. How do these attach to the floor and what am I looking to drill into? Just through the floor or into a cross beam or frame. Any help would be appreciated.
Crazzylenny is offline   Reply With Quote
Old 06-07-2017, 11:53 AM   #15
get me your email through private message and I'll send you a PDF I made for reference.
Old 08-03-2021, 12:20 PM   #16
I realize this thread is years old, but just stumbling upon it. That pdf you reference...do you still have it? Could you send it to me, as well? Are you still on this message board....Do you still have a van...? 😁
jmo1112 is offline   Reply With Quote
Loud Mobile
pinz712
My Van
bfolens
