Old 09-28-2017, 11:36 PM   #11
depark's Avatar
Originally Posted by SteelheadJones View Post
How do they drop the floors in these vans? Don't the floors sit directly on top of the frame rails?
Nope, there is surprisingly quite a bit of space between the bottom of the floor and the top of the frame rails. Take a look at page 2 of my gallery. https://www.sportsmobileforum.com/fo...ark-page2.html It shows what they cut out and how they dropped the floor 6". They get the full 6 inches by adding a 2" body kit.
Cheers
Darryl
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 09-29-2017, 08:22 AM   #12
shenrie's Avatar
id weigh the price difference of making your garage door taller if it was an option. my buddy just bought a hightop van and made his 3rd bay taller to accommodate the van. then its taller for whatever vehicle you end up with down the line. granted he did the work himself, but his out of pocket was roughly $150 to reframe the header and 1400 to get a new door installed. people usually keep homes longer than vehicles.
Old 09-29-2017, 03:35 PM   #13
depark's Avatar
I have a 8' door now and my HOA won't allow any higher. Also there just isn't enough space to fit a 9'. Good idea though. My search will continue.
Cheers
Darryl
VA7DTP
Old 09-29-2017, 04:07 PM   #14
Originally Posted by depark View Post
I'm limited with what I can fit in my garage. No raised roof will work. By the time I add 6" of suspension lift and 35's it will just fit with a regular roof.
Have you looked at the GTRV tops yet? If only adds a couple inches, if that.
Of course, I don't know if they install on used vans or even make an Econoline top anymore. And they don't seem to come up often used....
On that note... maybe you could just mount a donor roof over tge existing roof hole, add some hood struts and fabric, and viola! DIY GTRV top
Jim Bridger
wander
MCSporty
MSD
