Originally Posted by bettyford
You and me both. Where is it located?
Ron
It's under the driver's side door on the inside of the frame. If you kneel down and look under by your door you should see the ~1" exhaust pipe curving down right beside the frame.
Originally Posted by carringb
On you vans, does warm air come immediately after startup?
It's not been noticeable to me, but I will definitely check when I get the van back from the shop. I've had it down to -10 deg and it seemed to take a long time to get hot air. That was before I knew I had an Espar (great sales support from Chevy). I'm hoping the engine doesn't need to be running for the heater to work, that would seem to negate the advantages of an Espar.
